Disappearing Keyframes
Posted: Sun Sep 01, 2019 12:57 pm
by rafael
Not the first time I've experienced this and I'm assuming not the last either. Anyone know what's going on here? Some weird Moho quirk I'm just not aware of or is this a genuine bug? If so, it's a really REALLY bad one. (12.5)
https://www.youtube.com/watch?v=uuAN96lWaI4
Re: Disappearing Keyframes
Posted: Sun Sep 01, 2019 1:42 pm
I'd have to see the file to diagnose it. I've never seen that behavior.
Posted: Sun Sep 01, 2019 8:13 pm
That happens when you have the dimensions of a channel split, and only when you click without moving enough for a real keyframe to be created.
Posted: Tue Sep 03, 2019 9:18 am
by rafael
So essentially when dimensions are split it won't set a keyframe unless the value passes a certain threshold? That's unfortunate for me because I set a lot of keys here and there to hold positions longer and fine-tune timing.
Do you know if that's still the behavior in Moho 13?
Posted: Tue Sep 03, 2019 3:37 pm
rafael wrote: ↑Tue Sep 03, 2019 9:18 am So essentially when dimensions are split it won't set a keyframe unless the value passes a certain threshold? That's unfortunate for me because I set a lot of keys here and there to hold positions longer and fine-tune timing.
As long as you have those dimension channels already keyed, so they show, or set to always show, you can just double click the channel on the timeline to set a key for the current value.
Behaves the same in v13. This is on purpose, because just clicking a bone would keyframe both X and Y dimensions...in which case, it'd be better to have dimensions joined.
Posted: Wed Sep 04, 2019 10:00 pm
by rafael
[/quote]
[/quote]
SUPER helpful! Moho separate dimensions is quite different than AE separate dimensions and thus isn't as necessary for my workflow as I had thought. It took your message for me to really appreciate the difference. Also, didn't know about double-click.
You still can't copy/paste a separated key, which is an issue, but I've forwarded it to the support team.
Thanks again!
Posted: Thu Sep 05, 2019 2:53 pm
rafael wrote: ↑Wed Sep 04, 2019 10:00 pm You still can't copy/paste a separated key, which is an issue, but I've forwarded it to the support team.
Thanks again!
You just can't copy/paste the same value, but yeah, that does seem like a bug.
Glad I could help.
