Moho Pro 14 issue
Posted: Tue Sep 12, 2023 11:54 am
by Cobra5005
I just upgraded to Moho pro 14 and i have this issue:
https://ibb.co/ysDV3dW
How i fix it?
Re: Moho Pro 14 issue
Posted: Tue Sep 12, 2023 1:13 pm
by Víctor Paredes
I'm not sure, but it looks like you have the Fills deactivated.
Try go to the bottom right corner of the canvas Display -> Fills
Or right click over the Dragon bone layer, Quick Settings -> Fills and Apply
Posted: Thu Sep 14, 2023 2:05 pm
by Cobra5005
Nope it didn't work.
When i open Moho pro 13.5 it worked fine but not in Moho Pro 14 after i upgraded it
Posted: Thu Sep 14, 2023 3:01 pm
by SimplSam
This could be an issue with your Graphics Card vs Moho 14. When I turn off Fills I see a different image to yours.
What is your Graphics card? Can you check to see if you have the latest Graphics drivers installed?
(My PC without Fills)
(Your PC)
Posted: Fri Sep 15, 2023 2:37 am
by Cobra5005
AMD Radeaon HD 7500 Series/7570
Posted: Fri Sep 15, 2023 3:26 am
by Daxel
Cobra5005 wrote: ↑Fri Sep 15, 2023 2:37 am AMD Radeaon HD 7500 Series/7570
That GPU is 11 years old, the latest drivers on AMD's site are for Windows XP, so that may be the problem. It may not be able to run OpenGL 4.1.
SYSTEM REQUIREMENTS:
Windows® 10, 11 or higher
64-bit OS required
2.0 GHz Intel Core i3 or higher
4 GB RAM or higher
1.6 GB free hard drive space or higher
OpenGL 4.1 supported graphics card required (1920x1080 recommended) **
Online connection required to perform online activation
Posted: Tue Sep 19, 2023 8:26 pm
by 570295535
You can try turning off OpenGL by changing it to:
"DisableAllOpenGL" "TRUE"
"OpenGLEnabled" "FALSE"
In this file:
C:\Users\Administrator\AppData\Roaming\Lost Marble\Moho Pro\14\Moho Pro14.user.settings
Posted: Sun Sep 24, 2023 7:24 am
by Kaniggelundzylinder
Its a Bug.
Delete all Point Colors and
the Surface will be back.
Now You can insert new Point Colors.
