[PREVIEW ANIMATION VIDEOS] Issues with its Framerate
Posted: Wed Oct 25, 2023 4:28 am
by LuisArmengol
Hi,
We manipulate with ffmpeg the videos exported from Preview Animation to add some info in the video like these:
But we have some issues with the re-exported videos because ffmpeg (and VLC and Premiere) detects something strange with the framerate (maybe because a variable framerate) of the Moho exported videos. The problem I've found is that the re-exported video loses the last frame.
For example, for Previews Animation videos exported from a 24fps or 25fps project, the framerate is not exact
25fps > 25.20fps
25fps > 24.19fps
Could you check the settings when generating those videos if they are exported with Variable Frame Rate (VFR) and if its possible to export them to Constant Frame Rate (CFR) to avoid problems while manipulating those exported videos?
Thanks in advance
Re: [PREVIEW ANIMATION VIDEOS] Issues with its Framerate
Posted: Mon Oct 30, 2023 2:46 am
by LuisArmengol
I'm still in the process of learning how Moho works, so perhaps my questions may appear a bit unusual.
I've also noticed that sometimes in the Preview Animation video, frame 0 is included. Should it always be included? Never included? Logically, it seems that it shouldn't be present in the exported videos, and only the animation frame range should be included, but I'm not entirely sure how it should be, and why frame 0 is sometimes present in the video preview, while other times it's not.
