Clear Loop Cycles in Actions
Posted: Fri Jan 02, 2026 6:43 pm
Hi! I have a problem while im doing actions in a looping phases animation for a game
My problem is that for this animation I have to make offset keyframes for the movement of the hair and the tail of the character, I though that after making cycles in actions if you make a freeze pose keyframes between the beginning and end of the loop animation you can organize the action so it starts and ends correctly in the beginning of the action timeline
And yes, it does (I saw it works with most of the walk cycles) the problem is that when I play de action the cycle has a short break between the end and the begining frame (Im not repeating frames and all of them are in smooth), it gets solved if I duplicate the frames at its first loop but it is because the frames before the beginning and after the end are affecting the curse and the loop gets clear, how can I do it so the action itself works as a perfect cycle? or maybe there is a way to define the beginning and the end of an action in its timeline? Thanks! sorry for my english Idk if you understand what Im asking for.
https://gyazo.com/9df14a111e1476b0a0d91e40aa4ec788 This is how the slow break looks
https://gyazo.com/7463636bbde3f76359fb1a83e72c6294 this is how it looks clear when I duplicate frames
