Activation Limits for Serial Number?
Posted: Fri Jan 30, 2026 1:09 pm
I'm not sure if this is the best place to post this, but I wanted to check.
Is there a limit to how many times you can use the Serial Number to activate Moho? I recently switched to a new OS, Linux Mint. However, I was able to install and use the demo of Moho 13 perfectly fine with Lutris and Bottles. When I insert my Serial Number, it gives me this message:
A Fatal Error Occurred Loading the application
Reinstall this application to correct the problem (Error -3513)
The software then just gives me this message every time I've opened it. I've reinstalled it several times and like I said, the demo works fine, but the serial number insert breaks it. Could it be because there is a limit to how many times you can activate the software? I know a lot of you are saying Linux is a cause as well, since it's not native to it, though the demo worked perfectly so maybe it just can't connect to the internet via linux?
Either way, any help would be appreciated.
