Shapes are only selected if all their points are selected.
I hope you find it useful:
-- Provide Moho with the name of this script object
ScriptName = "LM_SelectPoints"
LM_SelectPoints = {}
LM_SelectPoints.BASE_STR = 2310
function LM_SelectPoints:Name()
return "Select Points"
end
function LM_SelectPoints:Version()
return "6.0"
end
function LM_SelectPoints:IsBeginnerScript()
return true
end
function LM_SelectPoints:Description()
return MOHO.Localize("/Scripts/Tool/SelectPoints/Description=Select/deselect points (hold <shift> to add to selection, <alt> to remove from selection, <ctrl/cmd> to toggle lasso mode)")
end
function LM_SelectPoints:BeginnerDescription()
return MOHO.Localize("/Scripts/Tool/SelectPoints/BeginnerDescription=To select points, drag a rectangle around them. You can also click on a single point to select it. Click on a curve to select the entire curve or click on a filled-in area to select an entire object.")
end
function LM_SelectPoints:BeginnerDisabledDescription()
return MOHO.Localize("/Scripts/Tool/SelectPoints/BeginnerDisabledDescription=A vector layer needs to be selected in the Layers window to use this tool.")
end
function LM_SelectPoints:Creator()
return "Lost Marble LLC"
end
function LM_SelectPoints:UILabel()
return MOHO.Localize("/Scripts/Tool/SelectPoints/SelectPoints=Select Points")
end
function LM_SelectPoints:LoadPrefs(prefs)
self.lassoMode = prefs:GetBool("LM_SelectPoints.lassoMode", false)
self.simplifyValue = prefs:GetInt("LM_SelectPoints.simplifyValue", 25)
end
function LM_SelectPoints:SavePrefs(prefs)
prefs:SetBool("LM_SelectPoints.lassoMode", self.lassoMode)
prefs:SetInt("LM_SelectPoints.simplifyValue", self.simplifyValue)
end
function LM_SelectPoints:ResetPrefs()
self.lassoMode = false
self.simplifyValue = 25
end
-- Recurring values
LM_SelectPoints.SELMODE_GROUP_PTS = 0
LM_SelectPoints.SELMODE_PT = 1
LM_SelectPoints.SELMODE_EDGE = 2
LM_SelectPoints.SELMODE_SHAPE = 3
LM_SelectPoints.selMode = MOHO_SELMODE_GROUP_PTS
LM_SelectPoints.selRect = LM.Rect:new_local()
LM_SelectPoints.previousX = 0
LM_SelectPoints.previousY = 0
LM_SelectPoints.allowShapePicking = true
LM_SelectPoints.ctrlKeySelection = false
LM_SelectPoints.isMouseDragging = false
LM_SelectPoints.simplifyValue = 25
-- The guts of this script
function LM_SelectPoints:IsEnabled(moho)
if (moho.drawingLayer:LayerType() ~= MOHO.LT_VECTOR) then
return false
else
return true
end
end
function LM_SelectPoints:IsRelevant(moho)
local mesh = moho:DrawingMesh()
if (mesh == nil) then
return false
end
return true
end
function LM_SelectPoints:OnMouseDown(moho, mouseEvent)
return
end
self.isMouseDragging = true
local lassoMode = false
self.ctrlKeySelection = false
if (self.lassoMode) then
if (not(mouseEvent.ctrlKey)) then
lassoMode = true
else
self.ctrlKeySelection = true
end
else
if (mouseEvent.ctrlKey) then
lassoMode = true
end
end
self.selMode = self.SELMODE_GROUP_PTS
if (not mouseEvent.shiftKey and not mouseEvent.altKey) then
mesh:SelectNone()
end
if (self.selMode == self.SELMODE_GROUP_PTS) then
if (lassoMode) then
self.lassoList = { { mouseEvent.startPt.x, mouseEvent.startPt.y } }
self.previousX = mouseEvent.startPt.x
self.previousY = mouseEvent.startPt.y
else
self.selRect.left = mouseEvent.startPt.x
self.selRect.top = mouseEvent.startPt.y
self.selRect.right = mouseEvent.pt.x
self.selRect.bottom = mouseEvent.pt.y
mouseEvent.view:Graphics():SelectionRect(self.selRect)
end
end
mouseEvent.view:DrawMe()
end
function LM_SelectPoints:OnMouseMoved(moho, mouseEvent)
return
end
if (not(self.ctrlKeySelection)) then
lassoMode = true
end
else
if (self.ctrlKeySelection) then
lassoMode = true
end
end
if (lassoMode) then
local g = mouseEvent.view:Graphics()
g:SetSmoothing(true)
g:Push()
local m = g:CurrentTransform()
m:Invert()
g:ApplyMatrix(m)
g:SetColor(MOHO.MohoGlobals.SelCol)
g:MoveTo(self.previousX, self.previousY)
g:LineTo(mouseEvent.pt.x, mouseEvent.pt.y)
g:Pop()
g:SetSmoothing(false)
mouseEvent.view:RefreshView()
table.insert(self.lassoList, { mouseEvent.pt.x, mouseEvent.pt.y })
self.previousX = mouseEvent.pt.x
self.previousY = mouseEvent.pt.y
else
end
end
end
function LM_SelectPoints:OnMouseUp(moho, mouseEvent)
self.allowShapePicking = true
return
end
lassoMode = true
end
else
lassoMode = true
end
end
local mouseDist = math.abs(mouseEvent.pt.x - mouseEvent.startPt.x) + math.abs(mouseEvent.pt.y - mouseEvent.startPt.y)
if (mouseDist < 8) then
-- Single-click selection - select a shape or curve under the mouse
self:SingleClickSelect(moho, mouseEvent, false, true)
elseif (self.selMode == self.SELMODE_GROUP_PTS and lassoMode) then
-- draw the finalized lasso outline
g:Push()
m:Invert()
g:ApplyMatrix(m)
g:LineTo(mouseEvent.startPt.x, mouseEvent.startPt.y)
g:Pop()
LM.Snooze(100)
end
self.isMouseDragging = false
if (self.selMode == self.SELMODE_GROUP_PTS and mesh:CountPoints() > 0) then
if (lassoMode) then
-- draw the lasso shape, and do hit testing
-- 1 - draw the lasso shape
local end1 = LM.Vector2:new_local()
local end2 = LM.Vector2:new_local()
g:Clear(0, 0, 0, 0)
g:Push()
m:Invert()
g:ApplyMatrix(m)
g:SetColor(255, 255, 255, 255)
g:BeginShape()
for i = 1, #self.lassoList - 1 do
end1:Set(self.lassoList[i][1], self.lassoList[i][2])
end2:Set(self.lassoList[i + 1][1], self.lassoList[i + 1][2])
g:AddLine(end1, end2)
end
end1:Set(self.lassoList[#self.lassoList][1], self.lassoList[#self.lassoList][2])
end2:Set(self.lassoList[1][1], self.lassoList[1][2])
g:EndShape()
g:Pop()
-- test code to view the lasso's shape
--mouseEvent.view:RefreshView()
--LM.Snooze(1000)
-- 2 - do hit testing on the lasso shape
local v = LM.Vector2:new_local()
local screenPt = LM.Point:new_local()
local m = LM.Matrix:new_local()
moho.drawingLayer:GetFullTransform(moho.frame, m, moho.document)
for i = 0, mesh:CountPoints() - 1 do
local pt = mesh:Point(i)
if (not pt.fHidden) then
v:Set(pt.fPos)
m:Transform(v)
g:WorldToScreen(v, screenPt)
if (g:IsFullWhite(screenPt)) then
if (mouseEvent.altKey) then
pt.fSelected = false
else
pt.fSelected = true
end
end
end
end
else
self.selRect:Normalize()
v:Set(pt.fPos)
m:Transform(v)
mouseEvent.view:Graphics():WorldToScreen(v, screenPt)
if (self.selRect:Contains(screenPt)) then
else
pt.fSelected = true
end
end
end
end
end
end
self.lassoList = nil
-- select shapes whose points are all selected
for i = 0, mesh:CountShapes() - 1 do
local shape = mesh:Shape(i)
if (shape:AllPointsSelected()) then
shape.fSelected = true
end
end
moho:UpdateSelectedChannels()
end
function LM_SelectPoints:OnKeyDown(moho, keyEvent)
return
end
if ((keyEvent.keyCode == LM.GUI.KEY_DELETE) or (keyEvent.keyCode == LM.GUI.KEY_BACKSPACE)) then
if (not keyEvent.view:IsMouseDragging()) then
moho.document:PrepUndo(moho.drawingLayer)
moho.document:SetDirty()
MOHO.DeleteSelectedPoints(mesh)
moho:UpdateUI()
keyEvent.view:DrawMe()
end
end
end
function LM_SelectPoints:DrawMe(moho, view)
if (self.isMouseDragging and self.selMode == self.SELMODE_GROUP_PTS) then
local g = view:Graphics()
lassoMode = true
end
else
lassoMode = true
end
end
if (lassoMode) then
g:Push()
m:Invert()
g:ApplyMatrix(m)
g:MoveTo(self.lassoList[1][1], self.lassoList[1][2])
for i = 2, #self.lassoList do
g:LineTo(self.lassoList[i][1], self.lassoList[i][2])
end
g:Pop()
else
g:SelectionRect(self.selRect)
end
end
end
function LM_SelectPoints:OnInputDeviceEvent(moho, deviceEvent)
return LM_TransformPoints:OnInputDeviceEvent(moho, deviceEvent)
end
function LM_SelectPoints:SingleClickSelect(moho, mouseEvent, tryToPreserveSelection, allowEmptySelection)
-- if tryToPreserveSelection is true, then don't change the selection if some points will remain selected
return
end
if (tryToPreserveSelection and moho:CountSelectedPoints() < 2) then
mesh:SelectNone()
moho:CountSelectedPoints(true)
end
if (not tryToPreserveSelection and not mouseEvent.shiftKey and not mouseEvent.altKey) then
mesh:SelectNone()
end
local i = mouseEvent.view:PickPoint(mouseEvent.pt)
if (i >= 0) then --pick a point
self.selMode = self.SELMODE_PT
if (tryToPreserveSelection) then
if (not mesh:Point(i).fSelected) then
mesh:SelectNone()
end
end
mesh:Point(i).fSelected = false
else
mesh:Point(i).fSelected = true
end
else
local point = mesh:Point(i)
point.fPrevSelected = point.fSelected
point.fSelected = false
end
end
local curveID = -1
local segID = -1
curveID, segID = mouseEvent.view:PickEdge(mouseEvent.pt, curveID, segID)
if (curveID >= 0 and segID >= 0) then -- an edge was clicked on
self.selMode = SELMODE_EDGE
local curve = mesh:Curve(curveID)
-- new method - select the points in the curve that was clicked on
local isCurveSelected = true
for i = 0, curve:CountPoints() - 1 do
if (not curve:Point(i).fSelected) then
isCurveSelected = false
break
end
end
local point = curve:Point(i)
if ((not isCurveSelected) or (point:CountCurves() < 2)) then
if (point.fHidden) then
end
end
end
else
if (not point.fHidden) then
point.fSelected = true
end
end
end
-- old method - select all points connected to the curve that was clicked on
-- take current selection and mark it special
if (point.fSelected) then
point.fPrevSelected = true
end
end
-- select everything connected to the picked edge
curve:Point(0).fSelected = true
mesh:SelectConnected()
-- turn the original selection back on as well
if (point.fPrevSelected) then
point.fPrevSelected = false
end
end
elseif (self.allowShapePicking) then -- try to pick a shape
local shapeID = mouseEvent.view:PickShape(mouseEvent.pt)
if (shapeID >= 0) then
self.selMode = SELMODE_SHAPE
--[[ -- take current selection and mark it special
end
end]]
-- select (or deselect) everything connected to the shape
local shape = mesh:Shape(shapeID)
for i = 0, shape:CountEdges() - 1 do
curveID, segID = shape:GetEdge(i, curveID, segID)
curve:Point(segID).fSelected = false
curve:Point(segID + 1).fSelected = false
else
curve:Point(segID).fSelected = true
curve:Point(segID + 1).fSelected = true
end
end
-- mesh:SelectConnected()
--[[ -- turn the original selection back on as well
end
end]]
end
end
if (not allowEmptySelection) then
local numSel = moho:CountSelectedPoints(true)
if (numSel < 1) then
point.fSelected = point.fPrevSelected
end
end
end
local preserveSelection = false
-- pass 1 - check if any of the selection is still selected
if (point.fPrevSelected and point.fSelected) then
preserveSelection = true
end
end
-- pass 2 - preserve the selection
if (preserveSelection) then
end
else
end
end
end
end
end
-- Tool options - create and respond to tool's UI
LM_SelectPoints.CREATE = MOHO.MSG_BASE
LM_SelectPoints.DELETE = MOHO.MSG_BASE + 1
LM_SelectPoints.LASSO = MOHO.MSG_BASE + 2
LM_SelectPoints.FLIP_H = MOHO.MSG_BASE + 3
LM_SelectPoints.FLIP_V = MOHO.MSG_BASE + 4
LM_SelectPoints.DUMMY = MOHO.MSG_BASE + 5
LM_SelectPoints.WELDOVERLAPS = MOHO.MSG_BASE + 6
LM_SelectPoints.SIMPLIFYCURVE = MOHO.MSG_BASE + 7
LM_SelectPoints.CHANGE_SIMPLIFY = MOHO.MSG_BASE + 8
LM_SelectPoints.SPLIT = MOHO.MSG_BASE + 9
LM_SelectPoints.SELECTITEM = MOHO.MSG_BASE + 10
LM_SelectPoints.lassoMode = false
function LM_SelectPoints:DoLayout(moho, layout)
self.menu = LM.GUI.Menu(MOHO.Localize("/Scripts/Tool/SelectPoints/SelectGroup=Select Group"))
self.popup = LM.GUI.PopupMenu(128, false)
self.popup:SetMenu(self.menu)
layout:AddChild(self.popup)
self.groupName = LM.GUI.TextControl(0, "Room For a Big Long Name", 0, LM.GUI.FIELD_TEXT)
self.groupName:SetValue("")
layout:AddChild(self.groupName)
layout:AddChild(LM.GUI.Button(MOHO.Localize("/Scripts/Tool/SelectPoints/Create=Create"), self.CREATE))
layout:AddChild(LM.GUI.Button(MOHO.Localize("/Scripts/Tool/SelectPoints/Delete=Delete"), self.DELETE))
self.weldBut = LM.GUI.Button(MOHO.Localize("/Scripts/Tool/SelectPoints/WeldCrossings=Weld Crossings"), self.WELDOVERLAPS)
self.weldBut:SetToolTip(MOHO.Localize("/Scripts/Tool/SelectPoints/WeldSelectedCurvesWhereTheyCrossOtherCurves=Weld selected curves where they cross other curves"))
layout:AddChild(self.weldBut)
self.simplifyBut = LM.GUI.Button(MOHO.Localize("/Scripts/Tool/SelectPoints/Simplify=Simplify:"), self.SIMPLIFYCURVE)
self.simplifyBut:SetToolTip(MOHO.Localize("/Scripts/Tool/SelectPoints/SimplifySelectedCurves=Simplify selected curves"))
layout:AddChild(self.simplifyBut)
self.simplifyText = LM.GUI.TextControl(0, "0000", self.CHANGE_SIMPLIFY, LM.GUI.FIELD_UINT)
self.simplifyText:SetPercentageMode(true)
layout:AddChild(self.simplifyText)
self.splitBut = LM.GUI.Button(MOHO.Localize("/Scripts/Tool/SelectPoints/Split=Split"), self.SPLIT)
self.splitBut:SetToolTip(MOHO.Localize("/Scripts/Tool/SelectPoints/AddAPointInTheMiddleOfSelectedEdges=Add a point in the middle of selected edges"))
layout:AddChild(self.splitBut)
self.lassoCheck = LM.GUI.CheckBox(MOHO.Localize("/Scripts/Tool/SelectPoints/LassoMode=Lasso mode"), self.LASSO)
layout:AddChild(self.lassoCheck)
self.flipH = LM.GUI.ImageButton("ScriptResources/flip_points_h", MOHO.Localize("/Scripts/Tool/SelectPoints/FlipH=Flip Horizontally"), false, self.FLIP_H, true)
layout:AddChild(self.flipH)
self.flipV = LM.GUI.ImageButton("ScriptResources/flip_points_v", MOHO.Localize("/Scripts/Tool/SelectPoints/FlipV=Flip Vertically"), false, self.FLIP_V, true)
layout:AddChild(self.flipV)
end
function LM_SelectPoints:UpdateWidgets(moho)
if (moho:CurrentTool() ~= "LM_SelectPoints") then
return -- this could get called when doing a double-tap on a multitouch Wacom device with a different active tool
end
return
end
MOHO.BuildGroupMenu(self.menu, mesh, self.SELECTITEM, self.DUMMY)
self.lassoCheck:SetValue(self.lassoMode)
self.simplifyText:SetValue(self.simplifyValue)
if (moho:CountSelectedPoints() > 1) then
self.weldBut:Enable(true)
self.simplifyBut:Enable(self.simplifyValue > 0)
self.splitBut:Enable(true)
self.flipH:Enable(true)
self.flipV:Enable(true)
else
self.simplifyBut:Enable(false)
self.weldBut:Enable(false)
self.splitBut:Enable(false)
self.flipH:Enable(false)
self.flipV:Enable(false)
end
end
function LM_SelectPoints:HandleMessage(moho, view, msg)
return
end
if (msg == self.CREATE) then
local name = self.groupName:Value()
if (string.len(name) == 0) then
LM.GUI.Alert(LM.GUI.ALERT_INFO, MOHO.Localize("/Scripts/Tool/SelectPoints/NameGroup=To create a group, you must first name it."))
elseif (moho:CountSelectedPoints() < 1) then
LM.GUI.Alert(LM.GUI.ALERT_INFO, MOHO.Localize("/Scripts/Tool/SelectPoints/CantCreateGroup=Can't create group - no points are selected."))
else
mesh:AddGroup(name)
moho:UpdateUI()
end
elseif (msg == self.DELETE) then
mesh:DeleteGroup(name)
moho:UpdateUI()
elseif (msg == self.LASSO) then
self.lassoMode = self.lassoCheck:Value()
elseif (msg == self.FLIP_H) then
local center = mesh:SelectedCenter()
if (pt.fSelected) then
local f = center.x - pt.fPos.x
pt.fPos.x = center.x + f
pt:FlipControlHandles(moho.drawingLayerFrame)
end
end
moho:AddPointKeyframe(moho.drawingFrame)
moho:NewKeyframe(CHANNEL_POINT)
elseif (msg == self.FLIP_V) then
local f = center.y - pt.fPos.y
pt.fPos.y = center.y + f
end
end
elseif (msg == self.WELDOVERLAPS) then
local didPrepUndo = false
for i = 0, mesh:CountCurves() - 1 do
local curve = mesh:Curve(i)
if (curve:IsSelected()) then
if (not didPrepUndo) then
didPrepUndo = true
end
local awr = LM_TransformPoints.autoWeldRadius
LM_TransformPoints.autoWeldRadius = 3
MOHO.WeldFullCurve(moho, moho.drawingLayer, mesh, i, moho.view)
LM_TransformPoints.autoWeldRadius = awr
end
end
elseif (msg == self.SIMPLIFYCURVE) then
local epsilon = MOHO.SimplifyEpsilon(self.simplifyValue)
if (curve:IsSelected() or curve:IsPartiallySelected()) then
didPrepUndo = true
end
--local beforePts = mesh:Curve(curveID):CountPoints()
mesh:AdvancedCurveSimplification(i, moho.drawingLayerFrame, 0.0, epsilon, 0.01) -- 0.001, 0.0001, 0.01
--print(beforePts .. "/" .. mesh:Curve(curveID):CountPoints())
-- MOHO.ReduceCurve(moho, mesh, i)
end
end
moho:UpdateUI()
elseif (msg == self.CHANGE_SIMPLIFY) then
self.simplifyValue = LM.Clamp(self.simplifyText:IntValue(), 0, 100)
self:UpdateWidgets(moho)
elseif (msg == self.SPLIT) then
local selectedEdge = false
selectedEdge = true
end
end
if (selectedEdge) then
MOHO:SplitSelectedSegments(mesh, 1, moho.drawingLayerFrame)
end
moho:UpdateUI()
elseif (msg >= self.SELECTITEM) then
mesh:SelectNone()
local i = msg - self.SELECTITEM
local name = mesh:Group(i):Name()
mesh:SelectGroup(name)
self.groupName:SetValue(name)
moho:UpdateUI()
end
end
