Hi, I'm trying to apply line boil to all of my shapes using styles, but moho 14 only seems to add the brush and colour information from the style, and the line only boils on the original layer.
It's the only style inside the file, and the style is definitely applied to the shape. Even other shapes in the same original shape layer will not have the line boil when the shape I have made the style from has it. Is it a bug or a setting I'm doing incorrectly?
Line Boil in 14
_conor_leech_
- Víctor Paredes
Re: Line Boil in 14
Do the shapes have a brush applied to them? Even if a style has a brush, if the shape has its own brush applied, Moho will show that brush instead of the one from the style.
If that is the issue, then you can select all the shapes and set the brush to none.
Or maybe the issue is simply the boil appears on the render, but it's not being shown in the preview. If that is the case, you can try going to Display, at the bottom right of the canvas, and turning off "GPU caching".
