Scripts MAGIC VFX PRO for MOHO
Posted: Mon Nov 16, 2026 8:15 pm
Hello everyone.
MAGIC VFX PRO Scripts for MOHO has officially been released!
Magic VFX Pro is a specially developed script that helps you create visual effects (VFX) in Moho quickly. You can flexibly customize every parameter to your liking, such as: in-time, out-time, duration, speed, color, curvature, and movement direction.
Everything is intelligently designed for the fastest and smoothest workflow. Simply click Apply, and the code will instantly draw the vector paths and generate ready-to-use animations tailored precisely to your chosen settings.
MULTI-LANGUAGE SUPPORT:
The script interface natively supports 12 languages directly inside Moho's settings, allowing you to switch easily for the most convenient workflow, including: Vietnamese, English, Russian, Chinese, Korean, Japanese, Spanish, French, German, Hindi, Arabic, and Portuguese.
INSTALLATION & USAGE:
Copy the tool file into Moho's Scripts folder (just like any other script).
Open Moho, select the Magic VFX Pro tool on the toolbar, and start using it.
DEMO VIDEOS:
Demo 1 (Drag A→B VFX): https://youtu.be/PlgEqNA-UnE?si=d5h6c2cmagW6E-uw
Demo 2 (Zone Circle VFX): https://www.youtube.com/watch?v=zW0-u3Cmdb8
This is a paid tool. If you would like to use it, please support me at https://czmotion.com
Thank you.
DEMO VIDEOS:
Thank you.
