Renderred output different form preview
Posted: Mon Jun 12, 2006 6:05 pm
by myxolam
Hi all.
Just discovered Moho. (still a long way to go with the tutorials.)
I am trying it out, but have a small problem.
I drew a circle as per tutorial and changed the color.
Mycircle is yellow in the viewport, but it renders green. (I had been playing with gradients earlier. )
If I try file/preview, I get the same yellow, but if I render , I get green.
(I hit the spacebar to confirm my color changes etc..)
seems I am missing something.
Are there any plans to make it possible to preview gradients? For those of you who have needed to use lots of gradients, was it an issue to not be able to preview them in the viewport?
Is there a way to lock layers?
Thanks Myx
Posted: Mon Jun 12, 2006 7:15 pm
by myxolam
I am not sure what happened with that file. But restarting Moho fixed it.
Thx
EDIT:
OK I see what happened. Gradient always overrides plain color(right?), So if you forget to change your previous color to plain then that happens.
