Totally new to Moho.... Customize UI + Wavy Line Style
andrew wood
Post by andrew wood »
Wonder if somebody could answer my stupid questions.
Can you customise the user interface at all so that it starts up the same way every time you load Moho?
Also...,
I want to create a character with wavy lines around it. Is there a line style that will do this?????
Many thanks for looking ive only downloaded it yesturday and love it but i couldnt find anything in the manual.
Andy.
Answer for #2: double-click the vector layer and then "Vectors". "Noisy Outlines" is an option which lets your lines wiggle at random from frame to frame. Experiment with diofferent setting. Note: this effect is lost when exported to .swf, it only works with bitmapped output.
andrew wood
thanks for the speedy reply!
its a great effect although i wanted to keep the wavy lines consistent im sorry i wasnt clear about that. Basically i want to draw Sponge Bob Square Pants but instead of trying to draw wavy lines around whiich may not work i was hoping to has a line type where its a consistant wavy line applied????
Cheers,
Andy.
