Moving over from Flash to Moho problems
Posted: Sun Aug 08, 2004 5:13 am
Hello everybody!
Wonderful that these forums are online. Ik hope someone can help me at this moment, so that I will be able to help other new people in this forum in a while
I have a lot of questions. Untill now, I have only used Flash as a tool to animate. I have used Flash since 2001. I do not always need to have swf output, I've also made animations for tv, but Flash is not really the right tool for such sort of work.
Then I heard about Moho. I downloaded the trial, saw the movies in the gallery, and now I am so enthausiast about Moho that I really want to learn to use this wonderful tool. So I have read the tutorials in the past weeks during my vacation, and tried to make some artwork, but then came my problems. It seems it is very hard for me personally to get used to a new way of making animations (learning new software).
Because of the fact that I only know how to animate with Flash, I really don't understand how Moho's animation method works. I am so used to Flash that I don't understand the differences.
- When making a Flash animation (for example, my latest project, the intro at http://www.wesa-ospel.nl ), I only use graphics, no MovieClips, and tell them if they have to loop or only display one frame. How can you do this in Moho? Moho does not have such a thing as MovieClips. What is Moho's way of animating? How do you get the same result (theoretically)?
- So far, I understood that when you don't want to see an animation anymore (for example a character, from a certain place in your movie), you must set the layer on that point to 'unvisible', is this correct or didn't I inderstand this? I can't manage to turn layers 'off', where can I find 'this button'? Or didn't I understand the 'turn layer off' function? In Flash you just remove the MovieClip from the stage.
- In Flash, in every frame on a layer you can draw a new drawing of a character to animate it frame by frame. How can you make frame by frame animations in Moho? Or do you have to use a new layer for every new drawing? Than you would end up with hundreds of layers (in Flash I always have about 100 layers in the end, for each little animation, and all those animations also have their own timelines _inside_ the clip... So that makes a lot mare layers... ). Is this true?
- In Flash I can re-use all the animations. I like the use of a library with all the artwork I made, and I re-use things a lot. I can drag and drop artwork on the stage. Did I understand well that, In Moho, instead of having a library, you work with 'the first frame in a layer'? Or is this something that is called a switch layer?
- Only when I WANT a tween, Flash makes one. But in Moho, when I move anything, there is created a tween directly. Can you turn this off when you don't want a tween at a certain moment?
In Flash there are keyframes, and normal frames. In Moho the tweens go everywhere automatically. or am I doing something wrong...?
- In Flash I can see the right colors already on the stage. In Moho I first have to render to see how the colors will look. It's hard to color things that way, I find. Is there a way to see the correct colors already during the drawing of the artwork?
- In Flash, I always make one long movie timeline. For example, the animation showed above at Wesa-Ospel, is a very big Flash file. Is it right to work the same way with Moho? I mean, for example the 'Good Spirit Song' movie I saw in the galery is really the kind of movies that I would dream to make. Is this one huge Moho project file, or do you have to make a new file for every camerashot, and than put all the small movies together in the end with video editing software?
As you can see, all these changes got me completely puzzeled. I really hope that somebody could take the time to explain the differences with working in Flash and working with Moho. Moho is a much better animation tool so I _have_ to get used to it
. I assume that it's just a new way of thinking, but I can't figure it out myself. Sorry for my bad use of the English language, I hope you can understand my point
Thanks a lot in advance!!!
