Simba (Lion King)
Posted: Sun Oct 01, 2006 6:57 pm
by clay82es
This is a Simba´s Draw.
The first render is the Simba´s head without the moustache and without other details in the ears as hair.
This other is a finish render to the sketch.
And this is a finish render with the colors and shadows.
Posted: Sun Oct 01, 2006 7:08 pm
by Patmals
Nice!!! very nice detail and colouring!
Posted: Sun Oct 01, 2006 8:43 pm
by Draw_Girl
WOW!! Did you use the freehand tool or a different tool to draw this? I can't draw too good in AS. Whenever try to draw spikey hair or sharp edges, AS always smoothes it out.....
I notice with your Simba drawing that his hair and the fur on the tip of tail isn't rounded off,how did did you do this?
Posted: Sun Oct 01, 2006 11:07 pm
by bupaje
In the Draw section of the toolbox there is a Smooth and a Peak tool which will enable you to convert selected point(s) to smooth or sharp. You can also use the shortcut P on selected points to make it sharp. There is also a 'Sharp Corners' checkbox with the 'Add Point' tool (in the Draw section again) which will make all the points sharp as you use the tool -useful if you are going to draw an object with lots of edges.
Draw_Girl
Posted: Mon Oct 02, 2006 7:43 am
by clay82es
Hi.
I never use for this sketch the freehand tool.
I use the curves system, and the tool is add point.
You can draw upstairs for some pictures.
Look, there are websites when I downloaded all characters.
http://members.fortunecity.com/agreeve/comicsbw2.htm
http://www.catsuka.com/gengal.php
Posted: Mon Oct 02, 2006 11:48 am
by Draw_Girl
Thanks guys.
