How do I easily cut a clear hole in an object?
Posted: Tue Oct 10, 2006 8:28 am
by DVTVFilm
Posted: Tue Oct 10, 2006 8:32 am
by jahnocli
You're describing a Boolean operation. There are no Boolean operations in AS -- it's a (mostly) two-dimensional animation program...
Posted: Tue Oct 10, 2006 8:33 am
by DVTVFilm
okay--thanks...
Posted: Tue Oct 10, 2006 8:35 am
by Trondheimfan
Remove the color from both objects, using the "delete shape"-tool (in the box's case, just from the light purple part). Now select both the square and the circle.
When you select the "create shape"-tool, you should already see that Moho treats the circle as a hole in the object. Just add the desired color, and there ya go.
Posted: Tue Oct 10, 2006 8:41 am
by DVTVFilm
Perfect--thanks...
