How to select multiple shapes?
Posted: Sat Nov 25, 2006 5:29 am
If you have 70 shapes on 1 layer, is there a way to select all shapes at once to give them a predefined style?
If I use that I only select the points of all shapes, I want to be able to select all shapes to change the colors or transpareny for all of them at the same time, maybe it's not possible? I don't know.slowtiger wrote:apple-A (on the Mac) does the trick - you have to be in the selection tool.
Thank you Rasheed! That is a way to speed it up a bit. I have to try it right away.Rasheed wrote:AFAIK you do this only with a style. You can speed up applying a style this way:
- Create a new style, or use an existing style
- Select a shape with the Select Shape tool and apply the style to the shape via the Style window
- Click on the same shape again, now with the Option key down to pick the style
- Click on the other shapes, with the Command and Option keys down to push the style to the shapes
