...reset bone/all bones on a swtich layer?!
Posted: Tue Jun 26, 2007 6:31 am
by funksmaname
Most frustrating... reset bones doesnt seem to work on switch layer bones!?!?
Any ideas?
Posted: Tue Jun 26, 2007 7:51 am
I've noticed this odd behavior in other situations. There are other things not available to a switch bone layer... can't remember exactly what it was off hand.
Sometimes when I was desperate I would actually change a switch to a bone layer using a text editor, do some stuff, then change it back. Not a good solution.
No way to fix this right now since reset bones is not a script, it is part of the application.
A scripted version like a new tool or menu script could be created to avoid this issue though.
I think what is happening is that AS sees the switch as a switch first and then "skips" it because it isn't "just" a bone layer... technically it is a group layer first, switches and bones are sub types of groups It could be that bone layers existed BEFORE switch layers in the program and the reset bone command just wasn't updated to include switch layers... this is just a guess though. Somewhere along the way it isn't being recognized as a bone layer.
This would be a good item for a bug report. This is definitely a bug.
Posted: Tue Jun 26, 2007 8:09 am
by funksmaname
*sob*
I just thought of a possible solution though...
could save the frame 0 bone positions in an action and just recall that whenever you want them reset?
Posted: Tue Jun 26, 2007 10:02 am
Yes that would work.
Clever idea.
Hey! This is even better than the actual menu! When using the reset bone command it resets EVERYTHING... scale rotation translation.
Most times you don't need that. If you use an action "reset" you can better control what happens.
Posted: Tue Jun 26, 2007 10:06 am
by funksmaname
yeah, and even - if you have a whole skeleton or more complex rig, you can set up reset actions for just parts of the rig (i've actually been doing just that to create localised blink/unblink actions for eye rig - but didnt see it as a solution to reset other stuff until now
Posted: Tue Jun 26, 2007 10:55 am
This is pure genius!
I have desperately been trying to come up with a solution for that problem!
My character rig has so many bone groups, eyes, mouth. etc Sometimes I just want to key all the frames for a subset of the whole group, I had to constantly select just those bones and key the frames otherwise I get unwanted frames where I didn't want them... or if I used reset bones it would key scale or rotation that would mess things up and clutter the time line.
Yeeehaaaa!
