Masking problems
dantoons
Masking problems
Post by dantoons »
can anyone help i wanna use masking, but ive read that u need a group, layer and that only in the pro version, unfortunately i aint got that yet! so could please someone help me
you can use a bone layer... it has the same masking functions as a group layer...
Mikdog
Post by Mikdog »
Masking only in the pro version? That sucks. I don't think so, though...
Make a group layer, put your layers inside the group layer, double-click the group layer, go to MASKING, select HIDE ALL.
Double-click one of your layers INSIDE the group layer. Go to MASKING. Select ADD TO MASK.
The other layer should have MASK THIS LAYER selected.
Now, I'm not quite sure which layer has what setting. Also, it makes a difference of the layer ordering, what layer's above what layer.
Best advice: Read and follow the tutorial about masking. It will answer your questions.
GROUP layers are only in the pro version... thats why i suggest using a bone layer.
mooncaine
Use masking to crop an image?
Post by mooncaine »
Could someone kindly post some step-by-step instructions for using a mask to crop an image, in Anime Studio Pro?
I've tried following the tutorial, and something's wrong. I'm confused. All I want to do is crop an image's borders so that it fits within a certain area, but I want to use masks so I can adjust it all inside Anime Studio Pro.
MacBook Pro 17", 2.16Ghz, 2GB RAM, 5400rpm 120GB HD
ASP 5.5 updated August 2007
OSX 10.4.9
Re: Use masking to crop an image?
mooncaine wrote:Could someone kindly post some step-by-step instructions for using a mask to crop an image, in Anime Studio Pro?
Please search the forum first :D
THIS took me only 1 minute. :wink:
mooncaine
Post by mooncaine »
Thanks. I did, else I wouldn't have bothered you. I did not find this in my searches. I tried more than one search, even. Sometimes it takes a veteran user to know what to search for, exactly, or what thread might have an answer.
OSX 10.4.9
