A couple exporting timeline problems.
Posted: Wed Nov 14, 2007 11:44 am
Hi. Wondering if anyone else is experiencing these problems and have found a solution.I'm on a Mac (OS 10.4) using AS 5.4.I don't seem to be able to export only a portion of the timeline.......for example....if I have a project thats 1000 frames long and if I export the whole timeline from frame 1 to 1000.....no problems, however...if I only want to export frames 800 to 830......I type this into the export settings, click OK....the render window appears......the bar at the top pulsates from light pink to light blue however there is no progress bar at the top and the window does not render....remaining white.Seems to me I've exported portions in the past without problem so cant figure out whats going on here and very time consuming to export the whole clip.
The 2nd issue is......If I export the whole timeline from 1 to 1000 without an audio track......no problem.....the export works fine....however....if I add an audio track to Moho....and export the same project at the same project settings.....I get a movie clip with the "black bars" on the top and bottom ......thereby changing the width/height that I've chosen.Whats going on here and how do I stop it? Thanks.
