Depth sorting issue
You drag a layer inside a group or bone layer up or down in the layer palette. (not a switch). You do this on any frame other than frame 0. Now select the parent layer, the group or bone layer that contains the layer you moved. There should now be a key frame on the "layer order channel".
Other than looking at your file I can't think of any explanation for not seeing a change in layer order. Are you certain you are dragging a layer that is visible?
Let me explain. I often have many group layers in one document. I may even have duplicates of the same bone or group layer. I sometimes get confused and try to do things on a layer inside a group that is covered by other group layers. Just a thought.
SaintMikey
Post by SaintMikey »
Well, I be damned- originally, I had the file set up for sorting layers by depth. As soon as I unchecked everything in that mode, boom!, the keyframes started to appear! I guess that's what heyvern was driving at.
Also, the parent layer of all this was a bone layer inside a switch layer: as soon as I removed the bone layer from that switch layer, boom! again, it started playing exactly as I want to. I have three views- side, front and 3/4 front- of each character inside a switch layer for more active positioning, though not every scene uses all of them.
I'm very glad to have this upgrade. But man, I wish they would have added explanations of this feature in the Help menu.
arfa
Post by arfa »
I am not sure that layer sorting-by-depth affects the appearance of keys on the timeline under 'layer ordering'. I am relatively new to AS so may be wrong but it seems as long as the layer is in a folder (bone, group - NOT switch) changes will be shown - outside frame 0.
It seems the layer has to be in a folder. A bit tedious but...
I had a character behind a door/wall and had to put the wall in the bone layer to be able to have her end up in front.
Layer order ANIMATION requires the layers be inside a bone or group layer. On any frame other than 0 you CAN NOT drag a layer OUTSIDE of a bone or group layer. You must be on frame 0 to do that.
However just reordering layers not in a group does not require this.
The keys for ANIMATED layer ordering are on the GROUP layer, not the layers being reordered.
If you have depth sorting turned on for a group layer and the z translation of a layer inside that group is changed reordering layers in the palette or any other way will not change how they appear. The z depth will override the layer order. If a layer is on top of another layer in the layer palette but its z depth is HIGHER or above any layers in the layer palette it will appear over those layers even if it is under them in the layer palette.
I would still recommend that all layers be inside either a group or bone layer unless you need to import layers into another document but you can do that as needed. It's just easier to maintain a document if everything is in at least one group or bone layer. Plus it saves time later if you plan to do more or need to use bones.
arfa
Post by arfa »
Yes, I had been wondering about this as a general standard. Getting basic work flow and processes established is a challenge for the neophyte as often the implications are far from clear. Planning seems paramount but not knowing what to allow for technically...
bit by bit -- or step by step if the pun is too much :)
thanks - arfa
