How do I import multiple images in one go?
creacon
Post by creacon »
thank you, I'll give this one a try.
I'll keep you posted.
creacon
7feet wrote:Are you intending to put all of the images into switch layers as it is? If so, I think I could whip up a quick mod of the script that would bring them right into a switch layer and automatically turn their visibility off. If the files for each switch layer were in separate directories, that should make the setup easier and hopefully help solve your memory difficulties. If that would help, I'll look at it.
EDIT- Whipped it up anyway, seems to work but I don't have any directories with enough images to see if it solves the memorey problem. But it does successfully drop everything into a switch layer and kill the visibility of the layer right after its imported. Let me know if that helps. Here it is:
http://www.sevenfeetdesign.com/moho/scr ... switch.lua
the only thing I have to look at is it's supposed to name the switch layer after the directory name, just to make life that little bit easier, but it doesn't. No biggie.
