neeters_guy, I will Google that guy and see if I can read up on some of his ideas.
Again, Thanks a ton guys/gals.
Oh I see what you are talking about. The white that looks like its part of the new clouds are in fact the old animated ones in a layer behind the new clouds. I thought I would leave them in there to give the sky some movement.fracturedray wrote:The clouds in the second picture are my vote.
I don't use Gimp but I'm sure there is a way to make a layer with alpha. That way you wouldn't get the white halo around the clouds and fire.
Is there a way?
My one suggestion it that you use the two clouds colors together. The one on the right you use to be on the side close to the sun. The one on the left you use on the side away from the sun.
Are you going to be able to mix these colors with the animated clouds you had?
I am glad you pointed this out lwaxana, the water fall scene (scene 5) is nothing near what I 1st posted, I'll post the new one in a week or 2. The Willy camp scene is this, minus I still need to draw the grass and bushes and some fishing gear.lwaxana wrote:It's looking great! As finishing touches, I'd adjust the shadow under Willy and behind the bottle and make them soft edged and lighter so they fit in the scene more.
About my waterfall comment long long ago, ;D this is what I was trying to get at:
It would add some nice drama if the camera was below the waterfall pointed up, like you had it before, but you would first see only the top of his head, then more and more from the top of his head downward because the edge of the waterfall would block him less and less from our view as he gets closer to the edge.
