Bones / Moho Stop Working
Old Dog
Re: Bones / Moho Stop Working
Post by Old Dog »
Thanks for the steps to install and run the script for negative key frames. It was easy to follow and worked just as described. It found ~~50 instances of negative key frames. I deleted them, saved the file, closed Moho and then restarted and reloaded the file. Run the script again and it found 2 more negative key frames. I deleted them and repeated the save, close, open, run script sequence several times and nothing was found. That's the good news. However, if there was an increase in speed for any interaction with the components of the file, it was marginal. I still get "Moho Not Responding" errors and the blue doughnut just wait.... It eventually resolves what it should do and completes the task, just changing layers, clicking on any menu item in upper left... I think the next step is to do a fresh install and see what happens.
Again, Thanks for the excellent help!
Old DOG (Designated Old Guy)
