Papagayo 1.2 problems
I will get this msg when running fom terminal:
Ulrik-Bod-ns-dator-2:~ ulrikboden$ /Applications/Papagayo/Papagayo.app/Contents/MacOS/Papagayo
Traceback (most recent call last):
File "/Applications/Papagayo/Papagayo.app/Contents/Resources/__argvemulator_papagayo.py", line 4, in ?
execfile(os.path.join(os.path.split(__file__)[0], "papagayo.py"))
File "/Applications/Papagayo/Papagayo.app/Contents/Resources/papagayo.py", line 23, in ?
import wx
ImportError: No module named wx
not launching.
ppc g4 dual 1.3ghz os 10.4.7
import wx
not launching.
The Eagle has landed
At least for me, version 1.2 is a go! Thanks for all of the hard work on this issue.
Oh, and not to be a dick but in the File menu Cut still has 2 t's.
Liset Agent 2.0 Tool: Linguistic Information Sound Editing
has anyone used this program before? Its free, great and should be integrated into the next release of papagayo! It would make lip syncing ahelluvalot easier!
OK, so here's what terminal says after the first thing that you advised us to type in:
...and here's what it says after the second thing you advised us to type in:
pythonw /Applications/Papagayo/Papagayo.app/Contents/Resources/papagayo.py
File "<stdin>", line 1, in ?
NameError: name 'pythonw' is not defined
Hopefully this helps. Hopefully someone's still reading this thread...
Thanks
Thanks
OK, so I downloaded Python, installed it and now this is what I get from Terminal (still no Papagayo):
>>> import wx
So, just to see if anything improves I typed in the next thing you wanted us to type in and I got this:
>>> pythonw /pythonw /Applications/Papagayo/Papagayo.app/Contents/Resources/papagayo.py
Don't know what it means but Papagayo's still not working. I've got a G4 running OS 10.3.9.
>>> import wx
wxPython, not Python.
Please excuse the extra hyphens (dashes) inserted in the Py-thon words - I'm getting some sort of posting permission problems otherwise - presumably some sort of security patch against Py-thon scripts sneaking through to the server in forum posts.
The cross-platform GUI Library, wxPy-thon, is needed as well as the base Py-thon (the programming language) - this is the "wx" library that is absent.
Py-thon on Macs does not come with this cross-platform GUI library included (I think it only comes some Mac-specific GUI library) - actually I don't think wx comes standard with any distribution of Py-thon.
See http://wxpython.org/download.php to get it.
Read that page very carefully - there's some further specific Mac stuff which depends on your version of MacOSX, which you may have to do before you install wxPy-thon (if you have Jaguar, you do need to re-install Py-thon, the basic programming language; if you have Tiger check the version of Py-thon and you may need to install a compatibility patch first).
Warning: while I have dabbled in Py-thon, I do not use a Mac. My advice comes second-hand.
Regards, Myles.
Regards, Myles.
-- Groucho Marx
-- Groucho Marx
off-topic
could any of the administrators
please fix the *posting* function
of the forum,
because it rarely seems to work
of the forum,
