can non pro version of anime studio export as sequential png
Posted: Wed May 06, 2009 2:21 am
by Holymonkey
Hi everyone.
I'd like to purchase Anime studio (standard version) but need to make sure it can export as sequential 24 bit png images WITH alpha transparency for the background.
Is this the case?
thanks
Posted: Wed May 06, 2009 3:47 am
by Genete
AS standard won't export to image sequence.
http://my.smithmicro.com/mac/anime/index.html
-g
Posted: Wed May 20, 2009 7:31 am
by n.hurst
I thought it might be possible to export an AVI from AS Standard, using an alpha-supporting codec like Lagarith or Huffyuv, and then a third party tool like VirtualDub to export the AVI as a PNG image sequence. Sounded good in principle, and it worked fine for non-alpha exports. However, neither of those codecs will export the transparency, even when configured appropriately. So, assume that is a limitation of AS Standard.
Workarounds might be to export a "green screen" style animation, then chroma key that to get the desired alpha'ed PNGs. Or export the animation as a Flash movie, then output the PNGs from that. But both approaches have their drawbacks, compared to the simplicity of exporting PNGs straight from AS Pro.
Posted: Wed May 20, 2009 2:24 pm
You can export with transparency to Quicktime MOV in AS Standard. Using the Animation codec and selecting its Millions of Colors+ setting. Then if you really need a sequence you'd need to do something like Hurst suggests.
Posted: Wed May 20, 2009 2:34 pm
Posted: Wed May 20, 2009 2:35 pm
by Holymonkey
thanks much for the advice/info.
Posted: Sun Jul 12, 2009 3:51 am
by Lebostein
Hi,
I have the same problem. I am very disappointed that I can't export single images. I tried an old Moho version before....
I have installed huffyuv now. If I open the export dialog (File/Export Animation...), then I see the normal option "AVI Movie". How I can export avi with huffyuv?
Thanks.
PS: I use Anime Studio 5.6
Posted: Sun Jul 12, 2009 6:20 am
by Lebostein
It's actually possible to export a movie with alpha?
I have tested:
- Lagarith v1.3.20
- huffyuv 1.3.1
- Quicktime
In every case I see the Anime Studio grey in the background.
What am I doing wrong?
Posted: Sun Jul 12, 2009 6:49 am
by jahnocli
Try Quicktime Millions of Colours +. The "+" is important -- this is the alpha channel...
Posted: Mon Jul 13, 2009 2:28 am
by Lebostein
Thank you! It works!
viewtopic.php?t=13927
