To change the Line With in the Style window your points must be "Reseted", select your points and go to: Draw --> Reset Line Width menu comand, then make the changes, SELECTING THE SHAPE with Select Shape tool, dont' use the Select Points tool (you must select point only when you want chenge width with the Line Width tool, and remember that working with brushes you must
deselect your shape to can preview the changes!
Toontoonz wrote:Yes, I know you can use the Line Width tool to adjust the line width, but there is no way to tell how thick the line width has changed; to 20? 3? 100? - the number in the Style line width menu does not change.
I've been trying to modify Line Width tool for add a number box to can control this, but nothing yet... (seemed
easy, but I don't know what happen with this tooll),I asked for this in the past too, in the scripting forum, but nothing, yet... (yet). And NOT, you can't use 0.25, 0.5 or 1.5...
Toontoonz wrote:The smallest line I could make was with a width of 1.
Jaja
...yes, more thin lines (PLEASE)
Feature Recuest
