Are you asking if I have done animation with vector illustrating programs such as Adobe Illustrator or Expression or others?Rasheed wrote: Toontoonz, I'm curious, you keep comparing Moho with vector programs for still pictures, but have you ever done animation with these pograms?
The answer is obviously no, because they are not animation programs.
(Rasheed, Which vector drawing programs do you or have you used?)
Moho says it is a vector animation program and allows the importing of vector drawings that are a .ai file.
To quote from the Moho website:
Moho is a 2D vector-based cartoon animation application.
Moho contains a vector-based drawing component, making it suitable for illustration tasks as well.
(Rasheed, have you ever imported an .ai drawing file into Moho? Were you satisfied with the result; i.e. the colors and line shape were the same in the vector drawing program as in Moho?)
When Moho says it is a vector drawing program and will import .ai vector files, one assumes that vector drawings that are interchangeable and true to color and form between other vector drawing and utilizing programs (Illustrator to Flash to Illustrator to Freehand to Flash to XaraX to Expression to Acrylic, etc, etc) will also work in Moho. But they don´t work too good when coming into Moho.
Soooo......with that limitation in mind (and since only very simple and basic .ai files import into Moho) I was hoping to learn how to draw with the vector drawing (and animating) program Moho.
I was thinking that my problems I was having with Moho was just because I was not used to its drawing tools and implementation of them. I have spent many, many hours working with the Moho drawing tools. But it is more than that. Moho can not create vector brush lines like other vector drawing programs.
Moho is not really like any vector illustration program like Expression or Illustrator or any other. All Moho can draw in vector form (if it even is a vector) is a sold line. All the other "brushes" are in reality just image files (not vector files) rearranged and alined and crammed together to form a textured looking line.
The image brush lines Moho makes have lots of problems when they are employed. So all one can really use effectively in Moho for line is a basic solid line.
In the forum:
http://www.lostmarble.com/forum/viewtopic.php?t=1871
Lost Marble made the comment of:
"Vectors can sometimes be too "clean". "
Well, Lost Marble, could it be that the vectors are "too" clean is because Lost Marble is not providing us good enough vector drawing tools???
Rasheed, have you created an animation using any of Moho´s brushes (other than the solid line)? Could you post them?
