Fade in fade out?
StickFights44
Fade in fade out?
Just wondering how to make a shape fade in and fade out in my animation
Two things I would do.
1st double click on the layer and select "allow animated layer effects"
2nd go to edit/preference and uncheck "enable drawing tools only on frame 0." This is not necessary but I prefer it unchecked.
Now you can go any where in the time line and lower the opacity in the layer setting and this will allow fade ins/outs.
StickFights44
StickFights44
Use the select shape tool. When the shape is "checkered" you can adjust the parameters of it, like the alpha of the shape, color, line widths etc while you are animating.
The alpha can be adjusted via the style palette.
StickFights44
