Exporting transparent AVI movies from ASP8
- Diana Kennedy
In earlier version of AS, when I had a file with a single figure and no background and exported it as AVI movie, this Movie automatically had a transparent background. Very useful to re-import in AS.
But in ASP8, this has changed. The background isn't transparent anymore, its either white or black. Is there a way to make transparent AVI movies again?
Export the animation.
In the Export Animation box do the following:
1. Export the project animation as a QuickTime movie.
2.In the render options select "Do not premultiply alpha channel".
3. When the QuickTime compression dialog appears, select the
PNG codec, and Millions of Colors+ as shown below. The
+ is QuickTime’s notation to include an alpha channel in the
exported movie.
4. Render the movie. Now when you bring the movie into your ASP8 it will include the transparency.
udd
As far as AVI goes you can do it with some codecs, but I can't remember which ones.
exported movie.
udd
If I remember well, this twouddhava wrote:As far as AVI goes you can do it with some codecs, but I can't remember which ones.
http://lags.leetcode.net/codec.html
http://neuron2.net/www.math.berkeley.ed ... ffyuv.html
- Diana Kennedy
- Diana Kennedy
You really need a codec, avi doesn't have alpha by default, so probably you had it installed before.Diana Kennedy wrote:Hm...I just tried out both solutions, but unfortunately, neither of them worked. By the way, I don't remember that I had to use a special codec in ASP7 in order to obtain avi with transparent background...
It's very weird you don't get alpha with mov movie. Check two things:
- are you sure you have activated "transparency" in "display quality"?
- open the move file and press crtl+I (or command+I in mac) and check the info of the mov movie, it shoud say "million colors +".
ponysmasher
- Diana Kennedy
ponysmasher
Well that doesn't work for me either. Did that work before? I know I've done it with Quicktime before but never Avi.Diana Kennedy wrote:Ponysmasher, I check it in Anime-Studio after re-importing the movie.
EDIT: Actually I might not even have used transparent Quicktimes now that I think about it.
- Diana Kennedy
ponysmasher
- Diana Kennedy
Boy...you are right...and that's the way I made it also in that time. How the hell could I forget that.
Yes, to be true, I didn't work this way (with imported avis) for some time, I had found better techniques. But now I have a task where I really could use the avi-import. So great thanks for digging out this forgotten how-to-do for me.
Really need to create transparent background
Wanted to thank you all for this post!
sharon seidl
www.wildlyengaging.com
