Is it possible to remodify the character made with the CW
Asterix
Post by Asterix »
Is it possible to modify the character made with the CW - like change some color?
GCharb
Post by GCharb »
Once the character is out on the work area, you can modify it in anyways you like!
Colors, shapes, etc.
Asterix
Post by Asterix »
Thanks, but I only see bones in layer. I can't select shapes to change color.
jonbo
Post by jonbo »
click on the bone layer in the layer palette to expand it, you should then see all the layers. you can also quickly select the layer you need to change by holding alt. and right clicking on the shape you want to select.
Jademunky
Post by Jademunky »
jonbo wrote:click on the bone layer in the layer palette to expand it, you should then see all the layers. you can also quickly select the layer you need to change by holding alt. and right clicking on the shape you want to select.
OMG. You have just saved me a heap of time. I hoped there was a way to do it to make it quicker but hadn't found it. Thank you!
