using masks in ASP 8 isn't recommended
superonIII
just wanted to write a "heads up" that it has masking options but it also has issues.
here's a recent response from a smithmicro technical type:
"Thank you for this information. I was able to reproduce what you described, and in speaking with the lead engineer for Anime Studio, he explained that this is indeed a result of changes made to the masking system, and that this is due to a limitation on the current masking technology. Version 8.0 had a different masking issue that was resolved with 8.0.1, but the fix for that previous issue is also responsible for this "jutting" issue that you're now seeing in 8.0.1. Because of the limitation of the masking software being used, fixing one of these issues will necessarily cause the other issue to resurface. Alternative masking technology may be considered in order to avoid both of these issues, but that will take some time and as such will likely not be available any time in the near future."
arg:(
arg:(
superonIII
- funksmaname
I use mask always and almost never have had problems. Maybe if you post your specific problem we can help you to get a workaround.
- neeters_guy
superonIII posted about this issue here:
Masking issues
I tried rendering 2.6_2.moho file as he suggested and the "jutting" issue is evident. The issue is hard to describe. It's like the part that is masked is slightly wider than the actual mask.
v.6.2 / v.8.01
Masking issues
v.6.2 / v.8.01
superonIII
i think i've been waiting for that post, looks like a great page you've put up there Gilles, thanks for your input. may i ask which version you used for this? sorry, maybe the info is in there somewhere...
it'll likely take me a few days to get through it and digest the information so until then i'll leave you with a picture of what it done to bits of my zebra...
(colour has been "enhanced" to make the problem more obvious)
if you carry on down after hitting rock-bottom you'll either get face-full of petrol or magma.
superonIII
ok, that's cool, it was a pretty quick one and explained the cutout situation well which was especially nice as i'll be using that a lot(once i've got the other things right:)
i must let you know though that following your instructions isn't so great for the stage "Click and drag from the center of the Moon image in the work area and bring the shape as closely as possible to the radius of the Moon."
as the layer has been placed in as a mask the moon image layer becomes invisible;)
so perhaps just put it in there after or turn off the masking at this point?
also... croissant moon? coolbeans
got me thinking that's were the term derives for a moment but had to see what wiki had to say:
"The word crescent is derived etymologically from the present participle of the Latin verb crescere "to grow", thus meaning "waxing" or "increasing", and so was originally applied to the form of the waxing moon (luna crescens)."
we can teach each other and both learn something new (not saying you didn't know that but i'm guessing it's quite likely).
just adding that i know looked up croissant on wiki and it tells me about the disambiguation, so i'm going to have to take back my teaching card and take another learning one instead;)
thanks again
thanks again
I use the masking tools a lot to create eyes and eyelid blinks, and haven't seen this problem to date. So I tried to reproduce this error and failed.superonIII wrote:i think i've been waiting for that post, looks like a great page you've put up there Gilles, thanks for your input. may i ask which version you used for this? sorry, maybe the info is in there somewhere...
So one question. On the mask layer ( the shape providing the mask outline), there is an option in 8 to exclude the stoke. Can you check your zebra layer to see if the exclude option (bottom of the dialogue) is clicked.
Assuming it is, then you could try using the stripes as a texture image. Without going into details (ie, posting character examples) I have a 4-legged character who could well be friends of your Zebra ... I found the texture images work really well.
Rhoel
superonIII
always a good option if the opportunity should present itself;)Rhoel wrote:...exclude the stoke...
Rhoel
with excludes strokes option.
i've made this one smaller, you can see the "lines" appear the same width whatever size the picture is, this helps me to think that it's not a vector line causing the problem. maybe vector line isn't the correct term but i felt some distinction need to be made here between the expected and otherwise unexpected. probably would have been simpler if i wrote stroke and line instead but too late now.
that's a good point though, i've tried really rather hard to not include strokes in the design but this thing just loves them, what version are you running Rhoel? chances are if you're not using 8.0.1 you won't see this.
here's a quick example for you:
open a new vector layer and make a square with no stroke filled with red (or whatever), now create another vector layer and make a white rectangle within that that bisects the square horizontally across the bottom half.
now create a bone layer and make it a masked group and use the square as the mask (drag layers into bone group), go back to the rectangle layer and change the layer blending mode to screen.
now preview... what do you see?
if i've written this clearly enough to follow you should be looking at something like this:
i'm pretty sure that's not right, honestly don't know though, can someone tell me different?[/img]
