Edge Artifcating - no fix?!
d-soldier
Post by d-soldier »
Preview window on left, render output on right... If the layer color is the same as the lower layer color, what are these edges all about? And why hasn't this been fixed in the new version? If anyone found a way around this and I missed it in the forum, please help me out here...
SvenFoster
Post by SvenFoster »
as a workaround... if you are only using images you can turn off antialias
I think its something to do with the antialias that has already applied..
(only works on the Export window not render and save.)
viewtopic.php?p=116361#116361
--Sven
What *if* the Hokey cokey *is* what its all about?
jonbo
Post by jonbo »
Check this thread, seems to be a similar problem.
viewtopic.php?t=19540&start=0&postdays= ... highlight=
Re: Edge Artifcating - no fix?!
If you're using patch layers, I've found that swapping the order of what is on top and below can fix these issues... worth a try!
