I put a keyframe hold starting at position 0. Now I want to remove it, but I can't figure out how. I know how to do at at other positions by sliding the hold bar backwards, but I don't seem to be able to do that at position 0. The documentation says you can right-click the keyframe and enter a number in the Hold Duration dialog, but I don't see the dialog.
Details:
Anime Studio 9.2
Windows 7
How do I remove a keyframe hold at position 0?
jessica951
Re: How do I remove a keyframe hold at position 0?
When you right click on the frame, there's an option called "Hold..." you enter the time you want to hold it for. if you dont want it to hold, then enter the value of 0. if you dont have any keyframes on the timeline, the zero keyframe will be invisible. If you entered an amount before, deleted all the other keyframes, the hold will still be there. to get rid of it, create a temporary keyframe and then right click on the frame 0 keyframe, select "Hold..." and enter 0.
