Re - Attach Toolbar
Kang
Re - Attach Toolbar
Post by Kang »
I am a dummy may bee, I clicked "Window > Tools" and wolla, my toolbar became detached. I want it back in the main window docked. I trued everything and can not find a way. restarting app or opening another project does not help. I can not find a default workspace either. What do I do to dock it back where it started from?
Anime studio pro 9
Editing this post, by default workspace, I mean that I can not find a reset gui workspaces to factory default. If there is a way to do that then clicking that should dock my tool pallet again since it is docked by default in new install.
drumlug13
Re: Re - Attach Toolbar
Post by drumlug13 »
On the tool bar at the top of the screen (File, Edit, Draw etc.) Click or hover over the "Window" tab. Then click on the window you want to re-dock. It should pop back into it's default place.
Adam
Kang
Post by Kang »
drumlug13 wrote:On the tool bar at the top of the screen (File, Edit, Draw etc.) Click or hover over the "Window" tab. Then click on the window you want to re-dock. It should pop back into it's default place.
Its the Draw, fill, layer, camera, workspace one, the one that reconfigures depending on what you have selected.
drumlug13
Post by drumlug13 »
Is there a check mark by it when you click the "Window" tab?
Adam
Kang
Post by Kang »
drumlug13 wrote:Is there a check mark by it when you click the "Window" tab?
WOW! I unchecked that before but had noe effect. I unchecked it now, and Wolla! My tool pallet is docked :) I think why it did not work before is because I have a 3d scene with a couple real huge image files on a couple of obj plane objects which are lagging the app bad. But all is well now, TYVM for the question, that solved the issue :)
drumlug13
Post by drumlug13 »
Sweet :D ... I was worried for a second because I remember reading a post a while back where someone moved a window off screen. I think they had to uninstall and re-install the program to fix it.
Adam
Kang
Post by Kang »
drumlug13 wrote:Sweet :D ... I was worried for a second because I remember reading a post a while back where someone moved a window off screen. I think they had to uninstall and re-install the program to fix it.
I moved window off screen to monitor 2 in another app, Cakewalk Sonar Producer, and when run app again with only 1 monitor, the item would not show and no way to get it back, had to connect second monitor and drag it back to monitor one. Another prob I had in same app is when using 2560x1440 pixel monitor and changing to 2048x1152 pix one, some of the items would bee off the screen and no way to get to.
Maybe that persons problem was related to this.
