Limitation to Nested Layer Control
RichardU
Post by RichardU »
CORRECTION: If you are using SB to animate vector layers in a subgroup, you can see it work while in frame 0, unless the subgroup is bound, then you need to move to frame 1+ to see it work.
RichardU
Re: Limitation to Nested Layer Control
Post by RichardU »
Post no longer relevant.
You could add bones to the parent layer that are duplicates of the bound child layer bones to control them 1:1 for top level control... i think?
RichardU
Post by RichardU »
I tried that. Also tried to link as an angle control bone. Couldn't get it to work, but there might be some trick.
It works like this (just tried it)
Bone layer (with bone B1)
- Bone layer (with bone B2)
-- vector layer
set up a smart action for B1 to rotate B2
CHECK BONE NAMES - if both B1 and B2 were called the same, it would not work (this happened to me when I initially tried as the first bone in each bone layer was called B1)
Now expand on this for a more complex rig :)
RichardU
Post by RichardU »
I did some experiments and discovered I had a flawed process for experimentation. I was testing bone action on frame 0. Everything works, until you make the sub-bone layer a switch layer or bind the sub-bone layer to some other bone. Then it doesn't work. However ... if you move to frame 1 or beyond, then it works no matter what. Fantastic, and thanks for the help.
3deeguy
Post by 3deeguy »
Quote by Funksmaname
Interesting Wrinkle: So the cure is to bind all of the sublayers directly to a top-layer bone and NOT bind the group layer. However, if the group layer happens to be a bone or switch type of group layer, and if the bone or switch layer contains any bones (yes, a switch layer can contain bones) then you will be unable to bind the sub-layers to a top-level bone.
Is there a way to use a switch layer with a smartbone? I did an experiment with a switch layer inside a bone layer. The switch layer had two vector layers. The smartbone effected the bone vector and a switch vector but I found I could not select a different switch vector without re-editing the smartbone action.
I was testing to see if I could select a different switch vector layer while turning a head. If not it's OK. I'm late to the party since I upgraded from ASP 7 to 9.5. Version 9.5 is amazing.
Cheers, Larry
RichardU
Post by RichardU »
3deeguy wrote:Is there a way to use a switch layer with a smartbone?
First, it's interesting to know a Switch layer IS a bone layer. You can add bones directly to it. Second, a feature of 9.5 is the ability of smartbones to control switch layers (pg 79 of the 9.5 Manual).
It's been pointed out in another thread yesterday that if you have switch controls in an SB they over-ride the main timeline so adding switching manually doesn't appear to work... I think the timeline should always override SBs - will make the suggestion.
RichardU
Post by RichardU »
I think Heyvern had written a script to control switch layers with a bone, and I had to abandon it for that same reason.
I have lessened desire to control a switch layer with an SB since you can now Ctrl-Alt-rightclick on a switch in the main window and set a key from there ... however, I have now experienced certain situations where Ctrl-Alt-rightclick simply does not work.
3deeguy
Post by 3deeguy »
It works! I made two vector shapes and put them in a switch layer. I then put the switch layer in a bone layer. I made two child bones for the vector shapes and made a 3rd bone to control the two child bones. Thanks.
Cheers, Larry
