copy animation between layers?
ulrik
Post by ulrik »
Hi mr.blaaa!
No I didn't get it to work, hmmm....strange indeed.
The alpha was still in the image and when I used it in "image texture" in Styles window, I was only available to load it in stretch mode, in tile mode it didn't show up at all...well I loaded it in stretch mode then, just to see if it would follow the layer movements from the cloned layer, and it did :D
unfortunately all transparence part were filled with white color :(
I have'nt tried to experiment with it futher, I just can't imagine what was wrong.
ulrik
Post by ulrik »
and yes I checked the image after rendering it, in tile mode it showed just white color where the image should have been
mr. blaaa
Post by mr. blaaa »
that is really sad, theoretically it shall work...
did u find another way to work around?
ulrik
Post by ulrik »
yes it should have worked, it was like a ghost that came in to this particular moho file...hehehe :D
Yes I made a work around, I made a new layer with the texture and animated the layer as close as I could to the original, you can see the result here: http://www.lostmarble.com/forum/viewtopic.php?t=2289
I think you allready seen it without knowing it was this movie I was talking about :wink:
Well I'm really glad that you're so helpfull and concerned, I found that a lot of people on this list is very kind and helpfull people.
mr. blaaa
Post by mr. blaaa »
ah, ok... now i have a clear conscience :D
8)
macton
Re: copy animation between layers?
Post by macton »
ulrik wrote:Is it possible to copy all animation (layer transpose, rotate, scale etc.) from one vector layer to another vector layer, or even better in my case, to a group layer?
Here you go.
I added a description for how you can do this with my load and save animation scripts. (And you could copy the animation data from a single vector layer to a group layer if you wanted.)
http://www.lostmarble.com/forum/viewtopic.php?t=2448
ulrik
Post by ulrik »
:D Macton, you're just sooo great!! thanks a ton
ulrik
Post by ulrik »
Hi!
I can't get this scripts to work, (crashcores "Load and save layer animation") I save the layer translation with "Save layer animation v1.4" from a vector layer and load it with "Load layer animation v1.4.1" in to an image layer and I get this message:
/cc_load_layer_animation.lua:614: attempt to index local ´layer´ (a nil value)
Does anybody know what I'm doing wrong? please help :?
macton
Post by macton »
ulrik wrote:I save the layer translation with "Save layer animation v1.4" from a vector layer and load it with "Load layer animation v1.4.1" in to an image layer and I get this message:
I'm not sure. Perhaps when I added the ability to save/load all the layer specific data the ability to save/load between different layer types was lost. I'll have a look and see if that's the problem - It's a good feature I'd like keep support for.
Dronowar
Post by Dronowar »
Try use Actions\Insert Copy :)
ulrik
Post by ulrik »
macton, it is indeed a good script and worth keeping updated :)
anyway, I managed to get it to work, in "save layer animation" I had to use the option "apply to all layers" and when loading the data with "load layer animation" I used the option "apply starting with selected layer" and voila!!
I thought I should use the option "only apply to selected layer" in both Load and Save script, but it didn't work.
Does "only apply to selected layer" means type of layer? then I understand why it didn't work.
Well I'm very happy for all your scripts, they do make things easier. :D
Dronowar, I don't think it's possible to use actions from one layer to insert in an other layer, at least I can't figure out how it should be done.
If you know how, please share it with me :)
macton
Update
Post by macton »
I've added copy and paste scripts specifically to copy generic layer attributes between different types of layers.
I've added instructions on how to do this as well.
See: http://www.lostmarble.com/forum/viewtop ... sc&start=0
ulrik
Re: Update
Post by ulrik »
That's great macton, I'll try them right away...thanks a lot, nice christmas present!, happy christmas and a happy new year to you. :D :)
ulrik
Post by ulrik »
I have a little problem with the "copy and paste generic scripts", when copying on a selected Group layer I get this message : 140: "tmpname" not supported, and when pasting at a vector layer (not that anything is copied I guess) I get this: 269: bad argument #1 to 'open' (string expected, got nil)
I'm using macintosh osx 10.4.3
macton
Post by macton »
ulrik wrote:I have a little problem with the "copy and paste generic scripts", when copying on a selected Group layer I get this message : 140: "tmpname" not supported, and when pasting at a vector layer (not that anything is copied I guess) I get this: 269: bad argument #1 to 'open' (string expected, got nil)
OK - I take this to mean that os.tmpname() is not available cross-platform. Let me look for an alternative and get back to you.
