Here's some handy scripts
- jakob polack
REVERSE KEYFRAMES -
hi there - this seems incredible BUT.....
I cant get it to work - i can add the script but nothing happens when I try it out.
is there some specific procedure about the LUA script or something <I have overlooked - does this script reverse animation of anything in moho ???
hey look here its my private webspace:
http://uk.geocities.com/jakobpcph/
- jakob polack
OKAY - I got the answer in one of the topic replys - It seems the reverse keyframes script only works for certain kinds of keyframes...
too bad - its not that useful then - but ahem - thanks anyway, keep up the good work :)
regards jakobPcph
regards jakobPcph
Update
* Load animation script updated
* Shift animation script updated
* Reverse animation script updated
* Splat animation interpolation settings script updated
See top of thread
See top of thread
Update
* Set last keyframe to cycle script updated
See top of thread
See top of thread
Today only - you get your wish... :)
Yes. It's there now.Ramón López wrote:I'm wondering if will not have you in mind modify your "Rescale" and "Save & Load" animation scripts to can work too with bone/point/shape animation
As far as I can tell, there isn't enough data available to the Lua scripts to do this.Ramón López wrote:And, another question, maybe it'd make possible something similar like Export/Import Actions??
Hasn't been that long
It hasn't been that long.Toontoonz wrote:Ramón - From just a quick scan through the posts, it looks like LostMarble has been absent from these forums for a long time, too.
Wonder what they are up to?
Been a looooooooong time since an update to Moho....
LM's last post: Oct 07, 2005
Last update to Moho: July 02, 2005
Just testing these now -quick question on Reverse Layer Keyframes if anyone can clarify.
I made a simple animation 144 frames, moved layer on frame 24, 48 and on 72 put back at start position reverse and when it plays back it only goes 2/3 of the way back. May be something with that Offset setting?
You can see what I mean here ...
http://bfenter.com/burtstuff/reverse_layer_1.mov
I also have a problem using Center Vector Layer To Points with a Switch Layer. I can set the origin for all the layers in the switch but the origin of the top level switch folder itself is not set/retained? I set it and then the layer origin seems to go back to center? I created Switch and added three vector layers Normal, Stretch and Squash - this may just be something I don't understand as I haven't used switch layers much yet.
The center vector layer to points only affects vector layers. It should not change your switch layer at all.bupaje wrote:I also have a problem using Center Vector Layer To Points with a Switch Layer. I can set the origin for all the layers in the switch but the origin of the top level switch folder itself is not set/retained? I set it and then the layer origin seems to go back to center? I created Switch and added three vector layers Normal, Stretch and Squash - this may just be something I don't understand as I haven't used switch layers much yet.
Not sure what are you looking for... center the parent layer on the average of all the points in the child vector layers?
