Hi Guys!
Looks like a great product! I'm trying to compile it under Linux. Hopefully it's possible.
This is what I'm getting:
12:51:27: Running steps for project Papagayo...
12:51:27: Starting: "/usr/lib/x86_64-linux-gnu/qt5/bin/qmake" /home/john/Downloads/dl/2014/dev/papa/Papagayo-master/Papagayo.pro -r -spec linux-g++-64 CONFIG+=debug CONFIG+=declarative_debug CONFIG+=qml_debug
Project ERROR: Unknown module(s) in QT: multimedia
12:51:27: The process "/usr/lib/x86_64-linux-gnu/qt5/bin/qmake" exited with code 3.
Error while building/deploying project Papagayo (kit: Desktop)
When executing step 'qmake'
12:51:27: Elapsed time: 00:00.
do i need a {multimedia} -dev module installed under my linux OS?
Thank you,
John
Compile 2.0 under Ubuntu Linux
JohnTalent
JohnTalent
Re: Compile 2.0 under Ubuntu Linux
sudo apt-get install qtmultimedia5-dev
fixed the problem.
now file/open doesn't recognize any .pgo or .wav files.
they don't show up in the UBUNTU dialog.
fixed the problem.
JohnTalent
changing to the follwing code helped files to actaully filter correctly under ubuntu.
QString filePath = QFileDialog::getOpenFileName(this,
tr("Open"), settings.value("default_dir", "").toString(),
tr("Papgayo and Audio files (*.pgo *.wav *.aif *.aiff)"));
installing libqt5-multimeida5-plugins solved the setMedia error.
so these 4 things got the latest source code to compile and run under Ubuntu Linux.
Enjoy!
Enjoy!
JohnTalent
The sacred.pgo file works fine for chris, but ross is way off sync.
any ideas?
any ideas?
