shoulders + body
TheMinahBird
shoulders + body
Post by TheMinahBird »
What I'm getting is this:
I want it to.. not do this. Heh.
However I prefer it to overlap the body. Like down below. But as it turns.. In many angles or y'know just around.
Is there anyway to achieve this? Oh, and I like it tapered off.
Thanksin advance. (sorry that I'm such a moron).
"Now hatred is by far the longest pleasure; men love in haste but they detest at leisure" - Lord Byron
Droxon
Re: shoulders + body
Post by Droxon »
Your images are broken, fix them so we can understand the issue. cheers!
TheMinahBird
saintbe
Post by saintbe »
Make a smartbone action on your armbone.
In the action you can adjust the points and align them to the shoulder so they don't seem out of place as you move the arm around.
It is explained well in this link
Hope it helps.
-Kim.
sbtamu
Post by sbtamu »
A simple example I just made. This might help you get started.
https://www.dropbox.com/s/97526cxakfyj7lj/arm.anme?dl=0
Sorry for bad animation
TheMinahBird
Yours seems to be a blank slate? For experimenting or.. ?
sbtamu
Post by sbtamu »
TheMinahBird wrote:Yours seems to be a blank slate? For experimenting or.. ?
Just an example for you too see how smart bones work.
TheMinahBird
Oh I see! It's so clean and smooth, I didn't even notice. ^^
sbtamu
Post by sbtamu »
TheMinahBird wrote:Oh I see! It's so clean and smooth, I didn't even notice. ^^
Open up the action window and look at what I did. I know it is a rough facsimile but it should aide you showing how to rotate the bones and moving points around along with curves.
TheMinahBird
I see you have a B1 and a B1(2) or something like that in a sense.
So these two are on the same bone? But never collide or screw up?
sbtamu
Post by sbtamu »
TheMinahBird wrote:I see you have a B1 and a B1(2) or something like that in a sense.
Yes, I usually use 4 seconds on the action time line and adjust the points as needed from 0-4 seconds. B1 is the arm moving away from the body from the at rest position, B1,2 is the same bone moving in front of the body from the at rest position. Once you understand how this works you be able to do some amazing stuff.
TheMinahBird
I see, I'll try to get the hang of it by studying yours more immensely. :!:
TheMinahBird
I think I screwed it up, do you have any tips on how detailed or how many points I can do in just one arm to make a 180 turn? Or must I split it like how you do? Doing two 90 turns? Because mine are crossing or one is just more dominant when turning the arm.
The other won't work while one will, is what I'm saying.
neeters_guy
Post by neeters_guy »
Try placing a circle guide at the bone base, and constructing the body and arm to match the circle:
TheMinahBird
Ah! Ok! I did that with the arm, elbow joints, I thought it wouldn't work with the body because of the size and etc. But thanks!
