Manual: Group layers in Debut
There seems no group layers in Debut? But the Manual of Debut talk about group layers some times. This is very confusing.
Re: Manual: Group layers in Debut
There are no Group layers in Debut, no. However, you can use a Bone Layer to do the same thing. You don't have to set it up with bones, you can just use it to group other layers.
~Danimal
You can also import a group layer from an existing file, like one of the tutorial files. You just can't create them in Debut.
You can open the *.anme file with a text editor and input
in the layer section. Save and reopen it in Anime Studio. And the new folder is visible. There are some other things you can turn on/off with a simple text editor if you have Debut only. I don't know why this file structure is not crypted or something. Very easy to read and edit.
layer_type 3
name "New Folder"
... other layers ....
