layer Z depth issue when constructing character
ruscular3d
I am not sure what I am doing to cause this, but when I construct a character, a few layers been moved on the Z plane and I don't know how it got there, and wonder if there is a way to lock layers onto the "0" setting on the Z plane. .77 seems to be the repeating depth of my layers from time to time.
- jezjones29
Re: layer Z depth issue when constructing character
Maybe you accidentally hit the 'alt' key when you were transforming the layer?
I've not had this problem before, but if everything is z:0 then it should be easy to spot.
ruscular3d
I program the alt key on my cintiq, and that could very well be what happen!
ruscular3d
Is there a way to lock out z depth to stay at "0"
- jezjones29
Not that I know of. The z only changes when you use the transform layer tool with the 'alt' key, or have the camera angled in 3D ('pan/tilt camera' changed from default or 'orbit' view enabled). When I'm working in 3D, I only manipulate the layer's positions with the numbers in the toolbar.
