In the Layers window click on the layer you want to rotate.killerham wrote:i dont think that this is a 3d program i just want to know how to make a character turn around
Go to:
Tools > Layer > Rotate Layer Y
Up in the top left corner of the main screen you will see "Y Rotation". It will be 0. Change it and your character will rotate on the Y-axis. If you have a mouse with a scroll wheel, click in the 0 window and scroll your mouse to quickly rotate it.
To get it quickly back to the 0 postion, click the RESET button at the top of the screen.
(An alternative - depending on what you want to do in your animation - one could also rotate the camera around the character, making sure the "Rotate to Face Camera" option is on in the Layer Settings options. The Character will rotate to always face the camera.)
A good tutorial to get the basic "2D in a 3D world" of Moho is do Tutorial 5.8 in the Moho Users Manual. (Tip: Don´t just read the Tutorials, actually follow along and do them.)
If you want to learn more about using 3D objects in Moho Tutorial 6.8 is a good place to start.
One of the best things to do with Moho is experiment. Make a character and then try each tool and see what it effect it has on your character.
