two circles
two circles
Hello,
How can I weld to circles together?
Thanks for your reply
sillyanimate
Re: two circles
what do you mean make two circles into one shape?
I think you can do with that create shape tool...
Don't forget! No one is perfect!
Re: two circles
Translate one point over another and hit space.
Re: two circles
That's exactly what I'm trying already the whole nightsynthsin75 wrote:Translate one point over another and hit space.
Does it only work for circles without fill and stroke?
Re: two circles
Are you using the transform points tool? Are you on frame zero?
Re: two circles
Yes I am on frame 0 and I use the transform tool. And for some reason I can't weld the circles when they have a fill and a stroke. Without fill and stroke, it works.
Re: two circles
What version of AS?
Re: two circles
11.2 build 18233 (64 bits)
Re: two circles
The new default way to weld is to hit enter.
If you want to change it back to the way it worked in previous versions change the setting at Edit Tab > Preferences > Tools > check box for "Classic point editing keyboard shortcuts". There more details in page 413 of the manual
Adam
Re: two circles
Ah, thank you all!
