Hi there,
I'm sure I'm doing something wrong, but my workspace animation preview does not show the curves of a vector based object.
For instance, I'm animating a simple circle. When I play the animation pressing the button, the circle changes to a polygon between the key frames.
However, if I run the animation through the timeline bar, I can see the changes on the circle between the two points.
Any configuration I'm missing here?
Thanks for your help.
Regards,
Rui A
Workspace animation preview "problem"
ruidelgadoalves
Re: Workspace animation preview "problem"
If you disable GPU acceleration, the curves will remain smooth in playback. Either way, the final render is not effected.
ruidelgadoalves
Where shall I disable GPU acceleration?synthsin75 wrote:If you disable GPU acceleration, the curves will remain smooth in playback. Either way, the final render is not effected.
Edit>preferences or display settings.
ruidelgadoalves
Not on my MAC versionsynthsin75 wrote:Edit>preferences or display settings.
I've only seen that problem with GPU acceleration. If you're sure you don't have that option, then you don't have an OpenGL-compatible graphics card.
But again, I've never seen AS do that without GPU acceleration. Can you post screen shots of your display quality menu and preferences menu?
