voice framesynch off in export, not in preview
rpc9943
Post by rpc9943 »
exported movie is completely off synch with the voice i did that shows perfectly in preview mode. can someone please help? I did a forum search came up with nothing
RonC
Jus_Me
Post by Jus_Me »
Did u speed up the audio in the timeline, I know it slows the speed down in the timeline on default setting, But if you modified the settings that could be it, Not sure tho, Im a noob :P
rpc9943
Post by rpc9943 »
i didnt speed up anything
i just imported papagayo data into it, seamlessly
preview is seamlessly correct
and now its not synched when i play it back exported...
please someone help
gavi dvan
Post by gavi dvan »
Just a thought..Are you exporting at the right frame rate? (Must be the same as the framerate you used in Papagayo)
This is a block of text that can be added to posts you make.
There is a 255 character limit
rpc9943
Post by rpc9943 »
i dont get why it would work in preview if it doesnt in export though- i havent checked but dont you think it would line up properly?
mr. blaaa
Post by mr. blaaa »
first of all:
which format did you use for export?
rpc9943
Post by rpc9943 »
okay first off i tried the raw avi, as well as the windows media compression.
both respond the same way.
if anyone has msn or aim try to contact me and i can send you the file so you can see whats going on
aim rpc9943
msn rpc9943@hotmail.com
RonC
mr. blaaa
Post by mr. blaaa »
Ok... I think there is some AVI related stuff and some different codecs i am not up to date with...
But usually the sound export to AVI was not possible, i guess it is yet possible with 5.3.
Try to export as quicktime movie format. It will work 100%.
