Hey
No idea how to set up phonetics in the moho -> papagayo bridge. Please help me. I did try loading the imported moho mouths, but they're not really making sense. Do I have to make a certain set of names? Why isnt there a preset for creating these layers?
Thank you everyone
RonC
Papagayo voicesync - How do I set up phonetics in moho?
Hey. Haven't worked a lot with this but I'll try help ya from memory anyhoo.
-In Papagayo, after you write your speech text, there's some button down the bottom to save it as a data file or something, so do that.
-Then in Moho, go to File\Import Moho object, go into the Papagayo directory and there should be a file called Mouths or something like that. Once you choose that you can select which mouth style you want and import it.
-Then go to Layer Settings of your new mouth layer, and select the tab, I think it's the last one, it should have something like "Import switch data" or something along those lines. Click that and select the file that you saved in Papagayo in the first place.
I think that's all there is to it, sorry I couldn't be more specific, this isn't the computer I animate on
This is a block of text that can be added to posts you make.
There is a 255 character limit
many users and me repeated the info on that the last month and the month before and and and...
Please, don't say there is no documentation on this, i remember well i posted several answers back to persons like you who where confused about lipsync...
(e.g. http://www.lostmarble.com/forum/viewtop ... o+phonemes)
So do a search containing "Papagayo" and "Phonemes" and i bet you WILL find something...
