Moderators: Víctor Paredes , Belgarath , slowtiger
sang820
Posts: 761 Joined: Fri Sep 10, 2004 6:55 am
Post
by sang820 » Sun Nov 27, 2016 3:17 pm
lwaxana
Posts: 1295 Joined: Wed Jan 06, 2010 6:50 pm
Post
by lwaxana » Sun Nov 27, 2016 5:12 pm
Beautiful animation cycle, Sang! And the design from Bergeres guerrieres is also stunning.
sang820
Post
by sang820 » Sun Nov 27, 2016 11:46 pm
lwaxana wrote: Beautiful animation cycle, Sang! And the design from Bergeres guerrieres is also stunning.
是的,他和他的伙伴是天才~!
Posts: 3832 Joined: Wed Feb 16, 2011 8:12 pm
Post
by hayasidist » Mon Nov 28, 2016 2:11 pm
Neat -- is that done with smart mesh? (and I assume you needed to make separate layers from the original?)
那很好! - 你使用“智能网格”吗? (我假设你不得不分开的层从原来?)
and I can't make a good translation of the text (is it shi yang???) before ".. to Jonathan Garnier" ! Please educate me!!
sang820
Post
by sang820 » Mon Nov 28, 2016 2:51 pm
hayasidist wrote: Neat -- is that done with smart mesh? (and I assume you needed to make separate layers from the original?)
喔,我没有使用“智能网格”,我分8层:库文件夹。遮罩层。羊头。披风。人物。羊的身体。枪。后面的手臂+羊腿。
我不使用骨骼,也没有时间分析和优化模型。但是我得到了Moho动画的乐趣---
这是十分愉快的。
是的,我是:shi yang(施阳)。
Post
by hayasidist » Mon Nov 28, 2016 7:11 pm
哦!
你的名字!! 現在很明顯,你告訴我! 我們太習慣於使用我們的用戶名! 我不驚訝,我不能翻譯它! 多麼笨拙的我! 謝謝。
sang820
Post
by sang820 » Tue Nov 29, 2016 12:06 am
hayasidist wrote: 哦!
不必自责,“人生在世,不如意十之八九”。“但行好事,莫问前程”
sang820
Post
by sang820 » Wed Nov 30, 2016 3:55 pm
sang820
Post
by sang820 » Thu Dec 01, 2016 2:25 pm
Posts: 3471 Joined: Fri Oct 29, 2004 2:13 pm
Post
by jahnocli » Thu Dec 01, 2016 3:46 pm
Nice sensual movement!
Post
by hayasidist » Thu Dec 01, 2016 5:05 pm
sang820 wrote:
我今天努力为线条添加了些“厚度”,然而还原度不是很好---我会再尝试其他方式,来还原羊身上那些可爱的云朵。
yes - I agree. I liked the simplicity and effectiveness of the stroke you showed on the train. perhaps two stroke shapes using the same set of points?
是的 我同意。 我喜歡你在火車上顯示的筆劃的簡單性和有效性。 也許兩個筆劃形狀使用相同的一組點?
sang820
Post
by sang820 » Fri Dec 02, 2016 3:39 pm
我会尝试新的方式---过两天会有结果
Post
by hayasidist » Fri Dec 02, 2016 4:28 pm
sang820 wrote: 我会尝试新的方式---过两天会有结果
我將等待!
讓我們希望成功!
sang820
Post
by sang820 » Tue Dec 06, 2016 3:47 pm
