darwing space
puzzles shum
darwing space
Post by puzzles shum »
i have some drawing on tracing paper how fit the on the screen .when i try to trace them on my pad they come out large and can't fit the hole darwing
Re: darwing space
Tricky. This method requires that your drawing fits the drawing pad. How about scan it in and trace in Moho?
puzzles shum
Re: darwing space
slowtiger wrote:Tricky. This method requires that your drawing fits the drawing pad. How about scan it in and trace in Moho?
is their video on this
Re: darwing space
Scanning is just 'taking a picture' of the drawing. If you don't have a scanner, you can just use a phone camera. After you have your image file, import it to Moho using the Import Image command. Once placed, you can scale it to your desired size. Tip: Set the imported art's layer settings to Don't Render This Layer.
puzzles shum
Re: darwing space
Greenlaw wrote:Scanning is just 'taking a picture' of the drawing. If you don't have a scanner, you can just use a phone camera. After you have your image file, import it to Moho using the Import Image command. Once placed, you can scale it to your desired size. Tip: Set the imported art's layer settings to Don't Render This Layer.
thanks for the help
