How do I start the physics of an object later than frame 1? For example, someone fires a cannon. I create the cannonballs and apply physics to them, which just makes them fall immediately, while still sitting "inside" the cannon. I tried "setting them down" on a non-moving object and then turning the visibility of the non-moving object off, essentially yanking it out from under the falling object. No good. The Physics settings for the falling objects aren't animatable either.
Also, what are all those keyframes for in the physics-enabled objects? In my test project, when I add physics to an object, about 200 keyframes are added for Layer translation and Layer Z Rotation. Deleting these keyframes doesn't appear to change the animation, though it spawns new seemingly random keyframes elsewhere. ????
Start physics later
- Jkoseattle
Start physics later
- jezjones29
Re: Start physics later
Have you tried setting your layer to 'start asleep' in the layer settings, and then using the 'Animation' > 'Nudge Physics Object' later in your animation?
- hayasidist
physics works by moving layers and creating keyframes ...Jkoseattle wrote:Also, what are all those keyframes for in the physics-enabled objects?
- Jkoseattle
But then why do the physics keep happening when I delete all those keyframes?hayasidist wrote:physics works by moving layers and creating keyframes ...Jkoseattle wrote:Also, what are all those keyframes for in the physics-enabled objects?
- Jkoseattle
OH!! That's kind of hidden. That's exactly what I want. The manual doesn't make that clear. Thank you!!jezjones29 wrote:Have you tried setting your layer to 'start asleep' in the layer settings, and then using the 'Animation' > 'Nudge Physics Object' later in your animation?
Thank you. I was wondering where the Nudge Physics dialogue box was.jezjones29 wrote: ↑Wed Dec 07, 2016 6:41 am Have you tried setting your layer to 'start asleep' in the layer settings, and then using the 'Animation' > 'Nudge Physics Object' later in your animation?
"If you can dream it, you can do it. Always remember that this whole thing was started with a dream and a mouse." - Walt E. Disney
