Why does "Create Smooth Joint" sometimes not work?
DrNibbert
Post by DrNibbert »
Hey everyone!
Why is "Create Smooth Joint For Bone Pair" sometimes greyed out from the menu if i do the exact same thing as when it works?
(Select Layer i want to Bind, Select 2 consecutive Bones - one parented to the other, hit "Create Smooth Joint")
Thanks for your help! :D
Showreel 2018 https://vimeo.com/254290989 - Moho 12.5.1, macOS 10.10, Adobe CS6
mrc
Re: Why does "Create Smooth Joint" sometimes not work?
Post by mrc »
It puzzles me as well sometimes. All I know is that the chain must consist of exactly two bones. If, say, an arm has 3 bones (upper, lower, hand) it doesn't work anymore.
Here's a workaround, tough:
http://lostmarble.com/forum/viewtopic.php?f=9&t=27158
Hope that helps a bit.
Marc
You don't agree with the post above? Click here.
www.tricklabor.com/en
mrc
Post by mrc »
Oh, and don't forget that the bones have to be in a relatively straight line in the first place.
DrNibbert
Post by DrNibbert »
mrc wrote:Oh, and don't forget that the bones have to be in a relatively straight line in the first place.
Thanks! Thats it!! :D :D
Finally i know why this keeps happening! 8)
