2D Mesh in MOHO 13 ?
Diana Kennedy
Post by Diana Kennedy »
Hm. I work a lot with the 2D Triangulate mesh in Moho 12. In 13 its called smart wrap, okay, but it just doesn't work, I mean:
The manual says that (highlighted in yellow)
And reality is this:
So WHERE is that selector?
Re: 2D Mesh in MOHO 13 ?
Might not be available in the trial version. Works here, in v13.
Diana Kennedy
Ok. Then I rely on your testimony that it works in the regular version. Thanks. :)
jmartins
Post by jmartins »
Diana Kennedy wrote: Fri Jun 28, 2019 10:31 am Ok. Then I rely on your testimony that it works in the regular version. Thanks. :)
There can only be two reasons that the Smart Warp menu doesn't show:
  • You don't have vector layer that is completly composed of triangles. To solve this you can go in the 'Draw' menu and use Triangulate shape.
  • You have Moho running as Debut
Smart warps are available on the trial as well as the full version.
João Martins
Diana Kennedy
Hm, none of these possibilites were in play, I used Trial Moho Pro, not Debut, But well, I just bought and installed MOHO 13 for good and true, here it is! Thanks ! :)
