Animate particle settings?
uncle808us
Post by uncle808us »
MacBook Pro OSX El Capitan Ver 10.11.6 Anime Studio Pro Ver.11.2.1:
Is it possible to animate the particle layer settings?
I use a MacBook Pro, and Anime Studio Pro 11.2
http://uncle808s.blogspot.com
Re: Animate particle settings?
No.
Depending on what result you want to achieve, it might be possible to animate 2 different particle layers with different settings, then fade one into another.
Also it's possible to animate the particle layer's properties like anything else, so you can change direction and size.
uncle808us
Thank you. I was hoping to animate the origin size and spread etc. but I can use your work around. Thanks
You need to enable 'Use Base Layer As Source' and then you can animate the size, as well as the shape, of the emitter.
uncle808us
Greenlaw wrote: Mon Sep 16, 2019 1:50 am You need to enable 'Use Base Layer As Source' and then you can animate the size, as well as the shape, of the emitter.
Ahh.. Yes Thanks...
Glad to help and I hope that works for you. :)
